It would be interesting to have the Level tab in addition to the properties of the button, as already present in the Fader properties, in order to assign a minimum and maximum value to one or more DMX channels when the button is pressed, without having to create a function to be associated with the button. button. See attached image
Button Level property tab
Negative - a button can be anything you bind to it. It would not make any sense, to control the DMX level of what is bound to a button, by the button itself. For a 1 to 1 situation, only dealing with solo fixture scenes, maybe... but neh.
Use level control sliders (pushing the lower limit) and use submasters to limit outcome (lowering the upper limit)
