More possibilities with the beat clock multiplier
tomray
Real Name: Tom Raymaekers
We recently had our wedding party, with the light driven by the QLC, Eurolite Pro USB to DMX interface, and alongside a MIDI-to-USB interface so the speeddial would match the beatclock of the dj-software. It worked almost flawless.
It would be great if all the divider/multiplier settings could be programmed seperately to a specific button or midi key (if possible on the same chaser activation midi key), so that the speed of some chases could be slowed down automatically when a specific chaser button is pushed, or speed up... (eg for a "slow" chaser scene, I could program the midi button to activate chase A AND multiply the speed dial by x8, and with the track with higher BPM, the button press would automatically activate chase D with a divided speed of 1/2)
Apart from that, this was by far the best program to use in a DIY-setup on our greatest day, with the opening dances programmed into your Show-tab, so thanks a million for makingt such a great and powerful program!
