I built a PC for the Light-Controlling of my Band last days.
I have the problem now, that QLC+ crashes when I load my current project-file.
On my Laptop, which is currently used for the light-shows, the file is working.
What can I do to find out why it won't work on the new PC ?
I attached the file here:
Thanks for your help
Julian
Crash when opening project
Do you have ALL the files in their right places?
^^ I got warnings about missing files,
hence,
it might be that you are experiencing user rights problems... Run under 'administrative rights' etc?
A copy from 1 to 1 is not assured, without 'exporting' the one and the 'import' 'it' to the other....
- Real Name: Julian
- Real Name: Julian
Nobody to help? I would like to have it running within the next weeks.
Open your qxw file with a text editor and reset two things:
- autostart function: remove Autostart="61" from <Engine Autostart="61">
- input output mapping: replace with this:
If it opens without crashing it means you have a mismatching IO mapping.
However I cannot solve your crash without any debug information
<InputOutputMap>
<Universe Name="Universe 1" ID="0"/>
<Universe Name="Universe 2" ID="1"/>
<Universe Name="Universe 3" ID="2"/>
<Universe Name="Universe 4" ID="3"/>
</InputOutputMap>
I have exactly the same issue. Made a showfile on a windows 10 laptop with QLC 4.12.5, now opening it on my new desktop with windows 11, same QLC+ version and QLC+ always crashes.
Windows event log:
Pad naar toepassing met fout: C:\QLC+\qlcplus.exe
Pad naar module met fout: C:\QLC+\qlcplusengine.dll
Fixtures are in the correct folder.
Where can we find extensive or more detailed debug / log info about the crash?
Windows event log:
- MULTI.qxw
- (241.46 KiB) Downloaded 43 times
- Shehds-LED-Wash-7x12W-MH.qxf
- (3.79 KiB) Downloaded 42 times
- Shehds-LED-PAR-12x3W.qxf
- (1.88 KiB) Downloaded 45 times
- Real Name: Julian
I did that, now I can open the project.mcallegari wrote: ↑Mon Aug 15, 2022 8:52 am Open your qxw file with a text editor and reset two things:
- input output mapping: replace with this:If it opens without crashing it means you have a mismatching IO mapping.Code: Select all
<InputOutputMap> <Universe Name="Universe 1" ID="0"/> <Universe Name="Universe 2" ID="1"/> <Universe Name="Universe 3" ID="2"/> <Universe Name="Universe 4" ID="3"/> </InputOutputMap>
Am I right that I just have to configure my input / output devices again ? So I have to activate the USB-DMX-Interface and the MIDI-Input-Interface ?
Thanks for your help.
Yes, throughout. What Massimo instructed you to do is to reset the I/O mappings in total (and the auto run function). We cannot simulate your connected devices nor your setup.julianb240393 wrote: ↑Tue Aug 23, 2022 9:31 am Am I right that I just have to configure my input / output devices again ? So I have to activate the USB-DMX-Interface and the MIDI-Input-Interface ?
