hello,
under the QLC 4.12.5 version in windows 11 environment, I have a cuelist which only contains music. I indicated the time of each piece to obtain the progress baree of the piece. But as soon as a piece is finished, the reading goes on to the next one. Is there a solution to stop playback after each piece of music.
Thank you
stop after each step of a cuelist
- Real Name: philippe thibault
ehhm yes ???
Set the duration of each step inside the chaser to infinite.
Now you have to progress the chaser by hand:
In your VC screen, create a chaser, bind it to your 'playlist'.
You now have to tap 'next' to go to the next song. The playlist will hold after each song.
You did created a 'playlist',Is there a solution to stop playback after each piece of music.
by forcing the duration to infinity, I lose the time progress bar, that's what bothers me. is there a solution to trigger a timer that starts and resets with each piece of the playlist.
thank you
thank you
