I just upgraded one of my Laptops to qlcplus_4.12.5_amd64.deb on a Ubuntu (22.04) and the uDMX device stops sending DMX signals (or they are not understood any more by the lights). I can reproduce the problem, when re-installing 4.12.4, it is working again. It could also apply to Windows, as I had similar problems there on a new Laptop, but thought that could be a driver problem.
If I remember correctly, some work was done in the USB area between the versions 4.12.4 and 4.12.5.
Does anyone have idea in which direction I could help debugging this issue?
Thanks,
Hans-Jürgen
uDMX device stops to work with 4.12.5
Hi, indeed there is something wrong in the port to libusb 1.0.
I can consistently reproduce the issue even if I'm pretty sure I tested that it was working before releasing
Gonna investigate what's wrong.
Found the cause!
Indeed when I tested it after the port to libusb 1.0 it was working....and then porting to Qt 6 broke it :'(
https://github.com/mcallegari/qlcplus/c ... 3370fd365b
Hello same problem for me but on windows 10
When using 4.2.4 all working ok,
when using 4.2.5, the uDMX system setting says:
uDMX
This plugin provides DMX output support for Anyma uDMX devices.
Device not in use
and I can't use it
I can provide additionnal details if required. Thanks for your support!
Regards
uDMX
Device not in use
and I can't use it
Regards
As mentioned above, the fix has already been applied.
Please use a test version until the next version is released:
viewtopic.php?f=12&t=3135
Thank you Massimo, I've tested with the very latestest one: QLC+_4.12.6.20.exe but unfortunately it doesn't work either....
Maybeinteresting for you: I have avast on my laptop and it has recognized the package as infected. I had to add an exception so the install and execution go through.
