In the Virtual DJ's documentation it's said that you can send multiple os2l commands at the same time by adding "&" bettween the two commands (e.g. os2l_button "Scene 1" & os2l_cmd 1 50%) but when I do that QLC+ receive neither of them... (they are received when they are sent separatly)
Is it an issue on my side or just that QLC+ doesn't support that ?
Else, can you tell me how to solve it or do it in a different way ?
Thanks in advance for your help
Receive multiple commands os2l
It's probably a not supported syntax.
Can you point me to an example that I can see?
I don't see any reference here: http://os2l.org/
Here on the Virtual DJ documention at the bottom of the page : https://virtualdj.com/wiki/os2lshowpertrack.html
Wireshark network sniffing?
viewtopic.php?t=11853
Thank you GGGss
So when Virtual DJ sends 2 commands in a short time, QLC+ execute neither of them and I have the same issue when I send a command on a beat (I fixed it by disabling the beat message)
Ok that is weird.
I need a VDJ project to replicate the issue. I'm not even sure I remember how to set everything up or if my VDJ instance still works. (I don't use VDJ at all)
- Real Name: Justin Hornsby
I've seen this too & my solution was to move os2l points of interest in tracks away from beat positions. I didn't have to shift them far at all, just about a 1/32 of a beat either way.
Maybe it's an issue with how multiple os2l commands are queued in VDJ & qlc isn't set up to interpret them?
According to the os2l protocol documentation (what there is of it) each drop should be individual. Maybe they're not. I never checked with wireshark - I probably should!
An update to this old thread:
I just played out a section of a track with a POI set on the beat, looped for 2 beats so the POI with OS2L button press should be sent out every other beat. Guess what? I grabbed the packets with Wireshark & VDJ isn't sending the POI reliably. This is an issue with VDJ's OS2L queuing, not QLC.
