Hello!
So I have created a simple show that should play a sequence. When I play the show (or the sequence) the sequence appears to not send DMX signals. Fixture Monitor does not reflect the values. The DMX fixture works fine in Simple Desk mode where all functions of the device work as expected.
Here is the sequence screenshot
Simple Desk screenshot showing DMX signal and the device does indeed respond great in this view.
Any ideas that I can check here? I feel it has to be a simple check box or config setting I am missing.
Sequence not sending DMX signals
Did you press the blue crosses under the faders of the simple desk?
If you touch them, they are a higher priority than everything else. So setting them to 0 still overrules everything else. You really have to unlatch simple desk by pressing the X'es.
