Hello there,
I got a problem with a custom fixture I just created.
The Fixture itself works well, every channel is mapped correct but unfortunately in the 2d Vis it only shows one head. The Fixture is a Strobe with Backlight Color LEDs (similar to Atomic3000LED).
https://www.thomann.de/de/varytec_color ... strobe.htm
The physical Dimensions are correct. I already tried to set the dimension bigger, change the rows of the head.
profiles but I'm still not able to get those "2 Heads" (Strobe LED and Backlight) to the 2D View.
Is there anyone who can help here? It would be so helpful for preprogramming at home.
Thank you!
Heads are not displayed correct in 2D
- Real Name: Julian
- Varytec-Colors-Sonic-Strobe.qxf
- (1.54 KiB) Downloaded 204 times
You are right... v4.12.4 does not show 2 heads...
test project file in annexe.
- 2headsno2D.qxw
- (2.76 KiB) Downloaded 190 times
