I’m using an RPi3 to run QLC+ and I’m extremely impressed and happy with it. I use an APC Mini for midi input to trigger scenes, etc.
I can’t get the programmable feedback colors on the pads to work. For example green when on/red when off and orange when bumping. When using the software a PC it works fine.
I wondered if it was inadequate power thru the USB port of the RPi so I bought an externally powered hub but that didn’t do it. The hub works because the pads and the wireless keyboard and mouse work fine thru it.
Hopefully someone has a tweak or suggestion as I prefer this setup. I run it headless with the APC controller and only go to the web interface occasionally.
APC Mini Pad Lights Not Working
- Real Name: Scott Herzig
Yes, sorry - correct there are only two states and yes, I have configured the feedback settings.
I use the APC with a PC and the ON/OFF lights work as expected. When using with the R-PI they never light up. I realize this could be a Raspberry Pi issue - not a QLC issue at all - but hoped perhaps someone already had dealt with the issue.
