Is it possible to add support to use the Avolites Titan Mobile controller, for Midi commands and 4 DMX outputs?
Support Avolites Titan Mobile?
- lorenzoandreani
- Real Name: Lorenzo Andreani
Maybe ... if you create a midi-profile
Since the device will be used as a midi controller, I'm quite sure that this won't work at all.
But why would you use an already implemented end solution to break it down and reimplement it with QLC+?
