Windows 11
Posted: Mon Apr 11, 2022 4:47 pm
by DeMeek
I today downloaded QLC+_4.12.4 on a Windows 11 laptop. After installation, the programm won't start up. The same with the fixture editor. After a a few tries, I downloaded the same on a Windows 10 laptop. And there are no problems. What is wrong?
Please keep your answers simple. I am Dutch and have not much Windows knowledge. A personal reply to
mmekenkamp@hotmail.com would be wonderfull!
Re: Windows 11
Posted: Tue Apr 12, 2022 4:35 pm
by DeMeek
I s this realy a difficult problem? I see a lot of views but no possible answers...
![Sad :-(](./images/smilies/icon_e_sad.gif)
Re: Windows 11
Posted: Tue Apr 12, 2022 6:08 pm
by sbenejam
Windows 11 is wrong I think. At work I avoid for now to upgrade to Windows 11. Can you provide more info about this error?.
Re: Windows 11
Posted: Wed Apr 13, 2022 7:52 am
Please try the latest test version:
viewtopic.php?f=12&t=3135
Re: Windows 11
Posted: Wed Apr 13, 2022 8:08 am
by DeMeek
sbenejam wrote: ↑Tue Apr 12, 2022 6:08 pm
I can install the porgramm but it won't start when I open it. Nothing happens. In Windows 10 I do the same and in runs, that's all I can say.
Re: Windows 11
Posted: Wed Apr 13, 2022 2:45 pm
by kenact
Have you tried run the install as Administrator?
Are there any errors from the install in the Application or System event logs? Are there any errors in the Event Log when you try to run the application?
Re: Windows 11
Posted: Wed Apr 13, 2022 8:06 pm
by DeMeek
kenact wrote: ↑Wed Apr 13, 2022 2:45 pm
Installing as administrator was the solution. It works, but only when I use the administrator account and not my normal account.
Thanks for alle the help!!
Re: Windows 11
Posted: Thu Apr 14, 2022 5:54 pm
Note to others:
When installing QLC+ for the first time, on Windows (Pro/Enterprise/member of a domain), the installer needs admin rights. This is because the installer needs to create keys in the registry. Running the installer with administrator rights solves the problem.
Re: Windows 11
Posted: Thu Jul 13, 2023 6:51 pm
by Maarten.Provo
Hello
I purchased a new Dell Precision laptop a few weeks ago which came with Windows 11. I believe I have a similar problem.
I installed QLC v4.12.7 with admin-rights (Installer fails without) and most of the times it won't launch. It will just sit there in task manager without doing anything. After termination I try again until after like 20 tries it will launch. When it finally launches it will then disconnect all of my usb-devices (I have to scan for new devices in device manager) before finally becoming operational. This is quite anoying.
Haven't tried running from the admin-account though. I would much appreciate any support you guys can give
Regards
PS: I use processor lasso to fix dpc-latency-issues on my dell.
Re: Windows 11
Posted: Fri Jul 14, 2023 7:35 am
Run QLC+ with administrator-rights... qlc+ right click, run as administrator.
Re: Windows 11
Posted: Mon Jul 24, 2023 9:06 pm
by Maarten.Provo
Hello
Turns out somehow my Traktor Kontrol S4 MK3 is involved.
If I launch QLC before connecting the Kontrol S4, no problem. If I launch QLC after having connected the S4 it will stay active (in taksmanager) but not show itself until I disconnect the S4 or (I'm guessing) the connection drops (which would explain why it seems to be random).
After a few tests, QLC seems to be working ok for now. Even with the S4 connected and after reboot it launches normally.
Regards
Re: Windows 11
Posted: Fri Aug 25, 2023 2:30 am
by ArturoWagner
If you are trying to run QLC+ as an administrator, you may want to make sure that you are logged into the system as an administrator. This ensures you have access and control over the lighting fixtures.
