Hello All,
I'm looking to be able to control my lights from an iPad. From doing some reading on the forum it seems like touch OSC is the way to go. My question is if anyone has been able to use touch OSC from an iPad to control QLC+ on a windows machine. Thanks in advance for any insight
Control Winows System With iPad
Depending on the complexity of your setup, touch OSC will work. But before investing hours of configuration, try the inbuilt web interface... This might already be your solution out of the box. Enable the webinterface, by setting a parameter when starting QLC+, and browse to the IP-address of the QLC+ host port 9999. Example: 192.168.0.10:9999 https://www.qlcplus.org/docs/html_en_EN ... eters.html
