Donner Starrypad is working, need feedback
beber666
Real Name: beber666
Hi
I'm new to QLC +, but I already love it !
I've been able to make the Donner Starrypad works, by simply re-affecting the pads like this (I've attached the configuration files).
I just would like to know if there is a way to get the color feedbacks on it, I know it's not supported, but I can try :-)
Thank you
neokob
Hi thx for your post it's help me very well.
Just need to know how have feedback by light on the controler
Without knowing anything about the device (does it support feedback?) Did you enable the feedback option in the in-output tab for your midi universe?
davideruff
Real Name: davide ruffato
hi, I tried to configure a starrypad donner on qlc but the program doesn't recognize the pads as keys.
Can you explain to me how you set them up?
thanks a lot.
Yestalgia
davideruff wrote: Sat Sep 30, 2023 4:37 pm hi, I tried to configure a starrypad donner on qlc but the program doesn't recognize the pads as keys.
thanks a lot.
Try reading though some of our brand new documentation :)
https://docs.qlcplus.org/v4/plugins/midi#configuration
You may need to change the channel for the midi input to "1-16"
davideruff
Yestalgia wrote: Sun Oct 01, 2023 6:58 am
thanks a lot.
hi,
I saw but the pad is not recognized as a button.
when I try to give it a value nothing appears.
Can I ask you to make a list with the steps to follow to make it recognizable? it tells me not supported
Yestalgia
davideruff wrote: Sun Oct 01, 2023 12:19 pm
thanks a lot.
hi,
Try changing the mode from Note Velicity to Control Change?
