is there a way to permanently re-sort the headings in a cuelist? I want to have the notes right after the steps.
Thanx, Gert
Sorting caption in cuelist
No ... but if you use a sortable number 01 02 03 ... this makes sense.
(If you want to make your life easier: open your project file with a text editor and change whatever labels you want there. Big warning: make a backup before, if you break the structure of the project file, the project will be unusable.)
- edogawa
- Real Name: Edgar Aichinger
As far as I can see, the headers/caption positions of a cuelist widget cannot be changed at all?
I think the wish to do so seems reasonable though, and it's as easy as changing a certain flag in sourcecode from false to true.
In <QLC+-srcdir>/ui/src/virtualconsole/vccuelist.cpp, line 168(when compiling against Qt5 which really everyone should do by now), after the change it should read
Making that persistent in the workspace fileis a different story, that would likely involve changes to the fileformat that would make it incompatible to older versions, I assume.
m_tree->header()->setSectionsMovable(true);
- edogawa
I can craft a pull request for this one-liner, if you like, so that future versions will easily allow changing column order for cue lists.
Personally I'd like to see that change, but thought there might be a reason why it was done the way it is, so I hesitated to PR immediately, in the hope some dev would comment here...
If you guys find it useful I can add it. (in v4...v5 is a pain for these kind of changes..)
