Hi there,
In our small amateur theater we have 2 Eurolite PLL 480 cw / ww spotlights in use. Unfortunately there is a problem with dimming:
With the mixer, dimming is done evenly up to about 80%, then there is a jump to almost full power. We have the same unpleasant effect with qlc +. Attempts to change the dimmer curves have not brought any success worth mentioning. Only if the master dimmer stays below 80% does this unpleasant jump do not occur. But this significantly limits the light output.
Can someone help us? Is there a similar effect with other headlights or has someone in the community created a corresponding fixure for themselves - maybe I can then copy the approach?
Many Thanks
Jörg
(Sorry, Translation with google translator)
Eurolite PLL480 cw/ww
If you are sure that the DMX monitor is sending out correct values, then the fault would be in the fixture...
Does this occur with the CW & WW channels?
- Real Name: Jörg Kampa
Thank you for your prompt reply.
It does not matter whether the master dimmer is set to 100% and the individual faders on the mixer or in the qlc + for cw or ww are pushed to 100% or the cw and / or ww are set to 100% and the master dimmer is moved.
Correct values are displayed both on the mixer and in the qlc. Other devices work fine.
In the qlc +:
If you switch to 100% directly via a button, the effect does not occur. If, however, a delayed fade-in is assigned to the scene, this error also occurs.
Greetings from Dresden in Germany
Jörg
In the qlc +:
Jörg
