Thank you Massimo for your great work!mcallegari wrote: ↑Thu Jan 13, 2022 4:30 pm For the record, Collection steps order is explained in the documentation, even with Scene + EFX example.
https://www.qlcplus.org/docs/html_en_EN ... ditor.html
EFX make strange LSB in position
- Real Name: Maxim
- Real Name: Greg_
After calculating the Pan/Tilt value after EFX, is it possible to add something like:
if Pan val >65535 set Pan val = 65535 (255,255)
if Pan val <0 set Pan val = 0 (0,0)
if Tilt val >65535 set Pan val = 65535 (255,255)
if Tilt val <0 set Pan val = 0 (0,0)
It's just an idea to eliminate the hiccups.
This won't help ... you have to make sure that the offset is set in such a way that the 'figure' does fit the window.GRE wrote: ↑Tue Jun 13, 2023 5:41 pm After calculating the Pan/Tilt value after EFX, is it possible to add something like:
If you see movers disappear from the view window and reappear somewhere else, this causes hiccups and the movers jump to the next calculated position (now back inside the window).
Having negative values set to zero, after some time, the calculated positive values will reappear and a jump takes place (without any in-between transition).
