QLC+ Raspi Terminal
djcrews90
Real Name: Dan Crews
Has anyone tried adding a touchscreen/driver to this? I'm able to download and install the driver using the terminal. But i'm too much of a novice to do it in this custom OS, as I can't open the terminal to run the download/install commands. Any help appreciated.
On which raspi image? If it's the, by Massimo provided, image, you can press CTRL+ALT+Backspace to get access to the shell.
Usage of touchscreens are well explained from page 9 on, in the provided .pdf with the image.
djcrews90
Brilliant! I read and re-read the pdf but kept getting stuck. I managed to install a 3.5 touchscreen on a raspbian image using the terminal to download the driver. But couldn't get access on the QLC+ image. Now I can, Thank you.
It's in paragraph 5.2 of the provided PDF
