Hello there,
So here is my set up.
I have:
2x EUROLITE LED KLS Laser Bar PRO FX (https://www.steinigke.de/en/mpn51741091 ... t-set.html)
2x LED strips
Running through the Advatek 16 MK2 (https://www.advateklights.com/pixlite-1 ... trol-board)
To a wifi router
Connected to a Raspberry pi running QLC+
Goal is to control all of this remotely with my smartphone via wifi connection.
I am able to get the QLC+ running and working with the LED strips.
But somehow I can’t get any signal to my Eurolites with QLC+ and generally.
I don’t know what I am doing wrong with trying to connect it. I have a XLR to Ethernet converter (no decoder) I think the Adavtek does that for me. (https://www.thomann.de/de/stairville_dm ... TJEALw_wcB)
Anyway. I know I am doing something wrong but what?
Thanks in advance
EUROLITE LED LASER BAR + LEDs + Advatek 16 MK2 - Troubleshooting
1. Wiring: ethernet to advantek, RJ45-XLR adapter from advantek _ DMX cable to led KLS #1, DMX cable from LED KLS 1 to LED KLS 2 (alternatively: separate RJ45-DMX to each LED KLS).
2. Check pinout of the adapter; advantek supports 2 pinouts; if neither matches, you have to resolder the adapter; thomann reviews suggest that the pinout is strange NOTE: check this before you plug the adapters anywhere!!! you may damage the equipment if it is wrong!!!
3. You have to configure DMX output(s) to some artnet/sacn universe; then you have to match that in QLC+ setup; note that universes are numbered from 0
For the cleanest setup keep LED KLS and LED strips in separate universes.
4. Start with sACN since it is able to output many universes on one IP address. art-net needs one IP for every 4 universes. To fully utilize the advantek device you'd need 25 IP addresses.
- Real Name: Rphael Denver
Don't spam this forumrphaeldenver wrote: ↑Thu Jun 02, 2022 7:36 pm Goal is to control all of this remotely with my smartphone via wifi connection.
@massimo please delete above post.
