Hello, everyone,
Today I received the DMX interface from Bitwizard (the board does not have the FT245RL chip on board) and tried every manual that is available on the internet. I didn't make it. I have now reloaded the image. Can you please show me a current tutorial?
Bitwizard
- Real Name: Dirk Rehlinghaus
hello massimo,
many thanks for the quick response. I have tried to follow these instructions, but I do not understand why I should install qlc again when I have installed an image that was ready before you? The link for Harold van Hulten's howo is also no longer available. Do I even need OLA for the bitwizard?
there is some notes in the official image PDF about bitwizard.
No help from there?
No help from there?
in the description there is a link, but it is invalid. Which PDF do you mean?
The PDF provided with the official QLC+ on the raspberry pi image
Hi there,
I have no idea what I've done now, but it works after the 5th time uploading the image.
Thanks for the support
By default, Bitwizard uses its XLR as an input (not output).
Did you instruct the Pi to set a high value to the GPIO output as needed?
