Hi. I have created some new fixtures, but Qlc+ dont recogize /load the fixtures. (Windows 7 Danish language). I suspect that the language is the problem, because the "Users" folder is translated. I have succesfully located and loaded the fixtures at my mac computer with some tweak because MacOS too, are using hidden user/support folders, and that s not a strait procedure as well. But Windows same problem, and im stuck! It would be a lot easy if the fixture folder was located more "open" and available.
Any hints to make QLC+ look the right place?
Lasse Luffe
QLC+ cant locate new fixture. local user folders sucks.
The related code is here: https://github.com/mcallegari/qlcplus/b ... e.cpp#L225
The User dir is fetched from environment variable UserProfile. Check its contents (echo %USERPROFILE%) and adjust it if needed... I don't know what happens to windows if you change it...
- Real Name: Lasse Luffe
SOLVED
Thanks. Thats what i just read. Its my fail. I was actually looking for the wrong titel of the fixture, and actually it works. So i feel a little stupid right now. I think i go to bed and get some rest:-)
