Run QLC+ in Kiosk mode RPI4
ada2000
Real Name: Delor Aprile
Hi, i woul'd like to run qlc plus in kiosk mode ,
how can i modify the file etc\init.d\qlcplus ?
It's possible by the terminal? because qlcplus boot directly with sd card "qlcplus_raspios_buster_20210627"
I try by ssh this command :
pi@raspberrypi:~ $ qlcplus -k
qt.qpa.screen: QXcbConnection: Could not connect to display
Could not connect to any X display.
It's not working too
Please help me
hi, this is basic linux usage question.
You can edit the file with the 'nano' editor.
Access via SSH, then type
sudo nano /etc/init.d/qlcplus
enter the password if asked, then add -k option to startup command
Then CTRL+O and CTRL+X to save and exit
ada2000
Thanks it's working , i'm a beginner on raspberry
