Is it possible to only show the virtual console page and non of the other tabs or toolbars? Basically what you get from web gui.
Also is there any screen saver option? I'm using the 7inch touch screen and don't want burn in if left on all the time.
Only show virtual console
It is called "Kiosk mode" please check the documentationIs it possible to only show the virtual console page and non of the other tabs or toolbars? Basically what you get from web gui.
https://www.qlcplus.org/docs/html_en_EN ... eters.html
Unless you run QLC+ on Xorg, there is no screensaverAlso is there any screen saver option? I'm using the 7inch touch screen and don't want burn in if left on all the time.
As a workaround, I suggest to put everything into a full screen multi page frame, and have one page with black background and no widgets.
