Hello Massimo,
Again, thank you for producing QLC+.
Since QLC+ doesn't directly support split color button backgrounds, as talked about in the following thread, I proceeded to create by own split color background images to use instead.
viewtopic.php?f=18&t=14131&p=63314&hili ... und#p63314
I tried to make a copy of a solo frame containing buttons with my custom background split-color images, however the copy was missing the background images on every single button. The buttons with single background colors as directly supported by QLC+ copied without issue. Same happens when you try to copy a single button.
Looks like either the copy or paste function is not taking background images into account.
Windows 10 + QLC+ v4.12.15
Resolved: Button copy - background image not copied
- Real Name: Tristan Young
Thanks for reporting.
Background picture was actually copied correctly but not immediately displayed. If you saved the project and re-open it, you could see correct background.
Anyway I have now fixed the issue.
Hi Massimo,
Thank you for letting me know. I didn't try the saving and re-opening of the project, but yes, now I see that it works as you said.
Glad to see you were able to fix it. Thank you very much!
