Hello everybody
Quite a long time i have come over here
I have just downloaded the last Maximo image for raspberry
I am trying to trigger a chaser by using gpio input without any success.
I have enabled GPIO plugin as input (with and without output also, just to be sure) for Universe 1.
In button configuration, autodetection does not show anything. I have also tried to set up manually the gpio pin.
But nothing is triggered by using a push button wired on the gpio pin (i have tried gpio.18 but also other gpio pns, as described in the documentation).
At last, using wiringPI, i could tell the state of pin is switching from 0 to 1 when pushing the button. It seems then the issue comes from my QLCPLUS configuration. Any help would be fine, thanks.
GPIO issue with last Maximo RPI image (raspios_buster_20210627)
That's a very good start, now you know your hardware is wired correctly. Now you have to make sure that QLC+ also looks at or pulling down or pulling up.
In the .pdf file, you can look up and make a change inside the config files.
Lastly, take into consideration that GPIO is flank triggered. It is not a 0 or 1 level, it is 'going to 1' or 'going to 0'
Thanks GGGss
I have been looking for information into raspberry guide and user manual but could not find anuthing regarding a change in a config file to get gpio works.
Could you be more specific please?
Thanks again for your help
- Real Name: Mark Z
I have not had a problem with GPIOs.
Again please make sure you are using a pull-down/pull-up resistor as required.
As an alternative, if you just need the capability to "push a button to do something" you can use any USB keyboard.
