Audio playback not working in the QLC 4.12.4
- Real Name: Roman
The older version worked fine, but the new 4.12.4 refuses to play any WAV files that I was using before. I her loud garbled noise for a few seconds, then silence. Tried new project - same thing. Both in the Show audio lane, or just hitting "play" on the file added to Audio in Function. Please advise. This is standard Windows 10 with built-in Realtek audio, same as before when it was working fine...
Thanks for reporting.
A couple of libraries were missing in the package.
Please check the latest test version and let me know if it works as expected.
- Real Name: Roman
Thanks, the audio is working now. The only thing I'm missing and desperate for is the ability to mass-select and copy clips in the show editor. I have a rock band, and doing verse and chorus sections would be so much easier if I could select all the clips and copy them to the next chorus for example. And also, if we change the intro and I have to slide everything 4 bars to the right, it seems to be impossible now. It's a big problem... Or maybe I'm not doing it right? We have a Show for each one of our songs that I'm triggering via MIDI. I have about 10 tracks on most songs. I just want to drag-select a large area, and also to be able to shift+select several clips. It doesn't seem to be possible now, does it?mcallegari wrote: ↑Sat Aug 07, 2021 8:33 am Thanks for reporting.
- Real Name: Marcus Kalvik
Hello! This is my first post. I want you, the developer to know that i really like this program, and it is something i want to use forever, but there is one single thing that bugs me, and that is the optimization of the Show feature. This is the only thing i need to have fixed for me to use this program to my intended use.
I have the exact same problem as roman now. This didn't happen before i believe. The program reads wrong values on WAV files and when you play, it's just weird high pitched sounds coming from it for a few seconds.
I have tried to download the newest test version, both before installing the main build, and after, but when i try to open it, i get this error "_ZdaPv start of prosess was not found in your library for dynamic connections, C:\QLC+\Qt5Gui.dll" (not sure if i translated it right).
I might start to use another program to read the frequencies, so i can just put in lights in QLC to match the frequency preview in Shows. That will maybe be just as efficient, but then i hope the song dont get out of sync 1-2 minutes later after starting from the start, as i heard someone complain about this too.
Latest test version for Windows should be OK now.
