Note: This advice is based on Qt Creator 4.14.2 on Debian 10.7 (Buster).
It could be that I and one other person are the only two that had trouble figuring this out, but to get QLC+ to build in Qt Creator, you have to turn off Shadow Build in the configuration. Here's a screenshot:
The build wiki says "Note: Out-of-tree builds are not tested and most probably do not work." I for one would emend that to say "...definitely do not work." Qt Creator defaults to "Shadow build" which is their term for out-of-tree build. Unfortunately, that approach leads to broken include paths in the test projects, among other possible problems. With "Shadow build" turned off, the Qt Creator build will be in-tree and will succeed.
This fixes errors such as "ui_assignhotkey.h" not being found.
Note that this will only make the build succeed. Debugging (without doing `make install`) is another kettle of fish, which I am still trying to straighten out for the case where I want to have a development version of QLC+ and a known-good version coexisting on the same system.
PROTIP: Turn off Shadow Build in Qt Creator
Thank you this is really helpful
