After extracting an RGB Matrix to a sequence in "Dimmer" control mode, the sequence still uses rgb channels of a fixture.
Moreover, all dimmer channels are set to 100%, and the rgb channels control the intensity.
I used led bars while expreriencing this bug, for example, in the "Noise" RGB Matrix pattern.
QLC+ 4.12.4
Windows 10
RGB Matrix to Sequence
Sample project please.
Also, does the original matrix work and this is only related to dumping to a Sequence?
The original matrix works, this is only related to the dumped sequence.
Added sample project with a fixture.
- Light4me-Mega-light-bar-led-8v2.qxf
- (6.02 KiB) Downloaded 93 times
- Sample Project.qxw
- (5.59 KiB) Downloaded 85 times
Hi, this should be fixed in the latest test version
viewtopic.php?f=12&t=3135
