I have some standard frames with buttons for multiple scenes. These frames contain hours of work. I copy them into another frame and use a master frame as a folder and then copy and paste them back in for shows. The frames go to specific songs.
Now my song frames that I copy and paste back and forth will no longer open. Can anyone fix this, if not this is going to cost me hours of work?
The file is attached
Frames Not Expanding
- Real Name: Dylan Casey
- 2021 ONE CHURCH 4.0.qxw
- (690.79 KiB) Downloaded 73 times
- Real Name: Mark Lohrey
I have seen this behaviour a couple of times and not sure what is the trigger but basically the frames have shrunk to just the size for the menu itself so when you click to expand it appears to do nothing.
The work around is to go into design mode and resize the frame (you will have to carefully click and drag the bottom right corner adjustor) to full size again.
It should work form there.
Cheers
Mark
Cheers
Mark
If you carefully edit the project file with a text editor (!!take a backup before editing!!)
You can tweak the settings of your frames:
