Submaster kills buttons
EphraimIII
In VC i have a solo frame with a submaster fader and some buttons. Each button triggers a different rgb-effect. When i move the fader it turns all buttons off. So i can't adjust the effects brightness while its running.
In previous releases i found this to be working.
Its sad, because i usually build my shows like that..
Anyway, keep up the good work!
Qlc=best!
sbenejam
Can you post your workspace project or a sample project explaining what you can achieve?.
Make sure the fader is in submaster mode. If you used this fader in playback mode before to change it to submaster, put in playback mode unlink the scene/function and activate submaster mode again. Or delete the fader and insert a new fader in submaster mode.
EphraimIII
Thanks for the response.
I found my mistake. Next to the buttons i had a very basic animation field to change the effects color. When this animation is placed inside the soloframe it turns the butten off when the submaster is moved. I moved the animation field outside the frame and BAM! Everything works just fine!
I will attach an example file..
Submaster_soloframe_test.qxw
(17.47 KiB) Downloaded 69 times
