Hello, using raspberry 3 B+, with QLC's disk image, I save the project in the device, but sometimes when I turn on the raspberry and select the qxw file, I get an error and the file is not working anymore.
I get "unable to access resource" error. Does anyone know how to avoid this error? And how to restore the file?
Thank you
Error opening project's file
I suppose this could be related to the SD card quality or power cuts?
You should try to avoid power interruption as much as possible, shutdown the system via web and use a good quality SD card
- Real Name: Craig
I am getting this too, just tonight, it started.
- Real Name: Keith
I have been flogging this one a bit also. Been doing the autostart file save on the pi using the right click show hidden files technique. I just tried deleting the file first then doing a 'save as' which worked this time. May have just been luck will report on any conclusive data.
I am using a high-quality SD card and pi approved power supply.
