I would like to ask if anyone has done something similar or has experience. With QLC + we want to control a multimedia fountain, but some of its elements are controlled via "WAGO I / O" and in addition it has a projector, which I would also like to control via a program and especially to create shows. That is, projection, switching on pumps and the like. We also want to enter the program via sensors / arduino and ethernet shield /, which will use the wind to adjust the height of the pump sprays and in case of rain do not even start the fountain. In addition, we have to come up with a timer that will turn the fountain on / off at the selected time.
Currently, there is a program "ecue", but it is more non-functional than functional and therefore the fountain is no longer the second year.
Video from the time when the fountain worked. [youtube] https://www.youtube.com/watch?v=Qe_lRia ... nel=sckesk [/youtube]
WAGO I / O terminal block composition: 750-841, 750-431, 750-431, 750 - 531, 750 - 531, 750 - 531, 750-600
The projector is also controlled over a LAN network and allows it to be turned on / off and the shutter closed / closed.QLC+ for multimedia fountai
hmm ... theoretically yes
but I don't read anything about Raspi, GPIO, Artnet, sACN or the like. So there is NO basic communication between the existing project and the 'world of QLC+'. So I'm sceptical.
(I'd have a look at f.i. ip-symcon which can perform the translation between Wago + network + sensors + ...)
- Real Name: Erik Kuzma
But I managed to solve the switching of the outputs via a DMX switch, the only thing I have to solve is whether it is possible to get the status of the devices back into QLC. As there is a bad link in the fountain about, for example, whether there is power from the mains, or whether there is a circuit breaker failure and others. Here I tied something to the MIDI style and project it into the program via the "console" so that the user can also see the feedback.
- Real Name: CodyX
@Erikkuzma: I think it is an WAGO I/O 75x Remote IO System. This is an Fieldbus Head. There is an Fieldbus-2-DMX512 Coupler available from WAGO:
https://www.wago.com/de/dmx
I think with this Coupler you can control your System with QLC+. But dont think that this is an easy task. I think your Fieldbus Head is individually programmed for your Fountain. So no one can say which channel means what. Expect a lot of hours of Trial and Error...
