If I open the program from the start menu, and then open the file, the save path is c:\QLC
If I directly open the file from the start menu, the default path to save as changes to c:\windows\system32.
I was scared when I couldn't find the file I had saved.
The program should always default to c:\QLC
Path to save changes if ...
This looks like QLC+ is run under administrative rights... I guess that running it as a user, the default path would be something like c:\users\<username>\documents or c:\users\<username>\appdata
If you double click a QLC+ project, does it
a) start QLC+ (.qxw is referenced in the right way to QLC+),
b) if you want to 'save as' ... which path is suggested?
