Beware the HDMI port on Raspberry 4: QLC+ does not seem to run if using HDMI 2
bertolt
Hi all,
I wanted to share a problem and the solution in case anybody else runs into this: I put QLC+ on a Raspberry Model 4 (4GB) but I seemed not to work: I attached a monitor to the Pi and when it booted up, I only got:
Raspberry GNU/Linux 10 raspberrypi tty1
raspberrypi login:
I tried: using another SD card, renaming .qlcplus to something else, but that didn't help. Only then I realized that the HDMI cable was plugged into HDMI 2. Plugging it into the other HDMI out showed that QLC+ was actually running. Silly me!
Greetings,
Bertolt
