Support for Multichannel Audio and multiple soundcards
Eicar
I'm planning to use QLC+ for a project that will require audio clips to be played on multiple soundcards on specific audio channels. (like front-left, center, back-left etc.)
I remember looking at QLC+ a while ago and I couldn't find support for this then. Is this still the case?
Is it on the road-map?
-Eicar
sbenejam
You can assign an specific audio device to an audio function in the audio editor. See: https://www.qlcplus.org/docs/html_en_EN ... ditor.html
In a theater play I used this option to play some audio to FOH speakers or to speakers in the stage through a Behringer UMC404HD. I'm using Ubuntu 20.04 with Jack Audio as sound server with many pulseaudio Jack bridge outputs as needed (I used 3 pulse outputs).
Which OS are you using?.
