Hi everyone!
Sorry for my English....i use "google translator"...
I recently purchased an Akai APC40 Mk2 controller. The my other APC Mini is perfectly usable, the "Flashing Feedback" is easy to see.
Question - Is it possible to do the same on the APC40 Mk2 controller?
I found in the Akai documentation how this is possible.I tried "MIDI-OX" an external program, and I was able to control it that way.
Example - Button 1: 90 00 50 - sends a control to the first button, where 00 - means the address of the button, 50 - color value
Based on AKAI documentation, for example: 9F 00 50, same Button, same color value, and "Blinking 1/2"
Unfortunately i can't find a solution to this within QLC +.
It can be solved with a MIDI translator program, but it is complicated.
Is there another way to do this, a solution within QLC +?
Thanks for answer.
Akai APC40 Mk2 - Blinking feedback ?
- Real Name: Ed Dixon
Following. I have the APC 40 mkII and would like the light to blink when active.
"Custom feedback" is what you're looking for:
https://www.qlcplus.org/docs/html_en_EN ... files.html
Also check MIDI plugin documentation (AKAI APC LED Feedbacks);
https://www.qlcplus.org/docs/html_en_EN/midiplugin.html
- Real Name: Franta
Documentation is not correct for APC40 Mk2. It is using different feedbacks than devices mentioned in the documentation. Unfortunately it is not possible to make buttons blinking using the custom feedback directly and it is neccessary to use sime kind of MIDI remapper for this purpose (such as https://www.bome.com/products/miditranslator)
MacBook Pro 2016 - Monterey, QLC+, AKAI APC 40 MkII, Fun Generation LED Pot System COB 40W RGB WW, Fun Generation Pico Beam 60 COB RBGW
