(before : sorry for my bad english, im a french guy ^^)
I dont know where can I post my request, but in the futur of QLC could you add a parameters of the WEB interface ?
Exemple:
- change the port of TCP/IP
- a checkbox for enable or disable the web service.
best regards,
Requaaw.
[4.12.x] Web interface settings
Do you mean the web server port?change the port of TCP/IP
What? Web server is a command line option. It's enabled (or not) at QLC+ startup.a checkbox for enable or disable the web service
Hello requaaw,
These are interesting suggestions. They should be posted in the Feature Request forum.
Right now, I do not think there is a way to change the port number for the web interface, and you must start the web interface by applying the command line parameter (like Massimo indicated). See the additional documentation here:
https://www.qlcplus.org/docs/html_en_EN ... rface.html
Good luck,
Mark
Good luck,
Mark
