Sorry, i'm french and i'm not very good in english (lol), but i don't find the good answer to my problem, so i try here !
I use QLC + (version 4.11.2) and Linux Show Player (version 0.5.1), with Linux Mint.
I use QLC+ for theatre, and I make a chaser to have a list of effect with time to up and down each cue. I use Korg Nanocontrol to go at each next cue.
What I want to do is inserting MIDI Cue in LiSP to have light effect in my cuelist, and to go to next light cue.
I configure LiSP and QLC+, and it's work... one time ! I send MIDI from LiSP to QLC+, I tried with Program Change and with "note on" (with a value to 127). The first time, the MIDI Cue to active the chaser works, and the MIDI Cue to go to next light effect works too, but if I back to the beggining to try another time, it's not working anymore... And if I make another MIDI Cue to go to the third effect, it doesn't work...
I hope it's comprehensible for you with my bad english !!
If somebody could try to help me....
Thank you !
Knard
MIDI with LiSP
Did you use an input-profile?
Did you try to tick (select) the 'Generate an extra Press/Release when toggled' option?
Did you verify all midi-parameters?
Please check https://www.qlcplus.org/docs/html_en_EN ... files.html
- sbenejam
Can you post your QLC+ workspace?.
