Triangle Lights 28 channel 8 pixel bar
- Real Name: Baz de Sylva
Help please. I have a show in a few weeks which includes four "Triangle Lights" 28 channel 8 pixel led bars. I have tried to write in the editor and can make the 7 channel mode work ok. I need the 28 chaannel mode for matrix effects but my 28 ch mode still operates as a single rgb mixer. I've watched Massimo's video several times but can't figure out my mistake.
- Bazza-28-chan-8-pixel.qxf
- (5.5 KiB) Downloaded 65 times
- Triangle LED Bar.pdf
- (1.97 MiB) Downloaded 79 times
You have to define 'heads'
Anyway please find the adopted fixture definition in annex.
Very weird fixture ... -> DO create a channel modifier for channel 3 (always between 40-79) See attached file
Added the channels & heads, the strobe is meant to be 'shutter' and other small errorsAnyway please find the adopted fixture definition in annex.
- Always 41.qxmt
- (370 Bytes) Downloaded 74 times
- (6.19 KiB) Downloaded 66 times
The .qxmt-file has to be placed in your personal 'ModifiersTemplates'-directory. (O.S. dependant) Windows: 'C:\Users\xxx\QLC+\ModifiersTemplates'
This is the channel modifier for channel #3.
