Adding a feature QLC+ to trigger show at specific time?
htucker
Real Name: Harrison Tucker
Hi everyone. I was wondering if it's possible to rebuild QLC+ from source and include a feature that lets you start a show at a specific time? I'm djing for a small event this weekend and need to be able to trigger different shows for different songs while I'm mixing. The problem is I can't simultaneously load up tracks, mix, while triggering the show. I need to be able to start mixing the track, and then when the track's intro breaks down, trigger the show from a specific time. Preferably from virtual console buttons. I have very little experience in programming and code, so I don't know if it's even possible or not. I'm using a Mac if that helps.
Any help would be greatly appreciated. I apologize if this was posted in the wrong section.
-htucker
djthomasryan
Real Name: Ryan Thomas Faricy
Assuming I'm understanding you correctly, this functionality already exists - add a Clock to your virtual console and you can schedule functions in the properties. :)
