Hello and hope all is well.
I think I've read about this before. I have a button for a basic LED par on scene, a button for a simple on/off chaser, and a submaster in a solo frame.
The scene works as expected with the submaster, but the chaser does not. When the submaster is all the way down, the chaser lights fully until I move the submaster.
Everything works correctly on 4.11.2.
4.12.3 on Windows 10 Home, ASUS Q503U.
The simple file is attached. Thanks!
4.12.3 Submaster Weirdness
Custom fixtures missing.
Please share or make a project with bundled fixtures
[EDIT] issue confirmed on buttons. If you use a Cue List it works
- Real Name: David
Thanks for the reply.
Here is the simple file with generic RGB. I did see the submaster works correctly with a cue list. Problem is I have a lot of chasers and no available screen space for any more cue lists.
Hi sorry for the delay.
I've got major issues with the Windows automated build system, so i had to build manually.
Can you please try the latest TEST version and see if it works for you?
Get it here: https://www.qlcplus.org/forum/viewtopic ... 35&p=14583 (20201105)
- Real Name: David
Sorry, I just saw this (a month later LOL). I just downloaded and tested 4.12.4 and it seems to have fixed the submaster with chaser problem. Thanks! Looking forward to the full version of 4.12.4.
