Running with no GUI
unky
Real Name: Łuke Skywalker
Hello
Is it possible to run qlc with NO GUI mode?
Reading doc it possible on Raspberry PI version only. -n or -nogui from command line.
How to do it on Linux-Ubuntu? I need it to run on linux server where there is no gui installed.
I will edit my qlc scenes on GUI system but after that in production it has to be executed on no GUI server.
lighthacker2020
Real Name: Mr Mike
I guess before getting in to the gui/no-gui discussion, I don't know for sure if --nogui works on Linux that isn't a rPi. Would it be an option to install something like the Tight VNC server on the "production" system? It will provide the graphical context for QLC+ to use. If access needs to be controlled, you can disable remote access to the VNC server, otherwise you gain the ability to monitor/modify the configuration through the VNC connection.
Nikoh
Real Name: Nicola
I join this question; is it possible to run QLC as a service without xorg?
I think i can create a virtual raspberry with proxmox but i would like to avoid it...
La violenza è l'ultimo rifugio degli incapaci
Nikoh
Real Name: Nicola
Ok, thanks.
If i try to run qlc+ from cli (kernel with nomodeset enbled) it start or get me an error?
Nikoh
Real Name: Nicola
Ok, tried and work but in short i think that qls+ desktop is necessary to set up devices and environment...
Massimo, which one do you recommend between xfce, lxde and mate?
I think the default xfce would work just fine
