[4.12.3] Current value disappears when changed [fixed]
The issues found when using the web interface
susnux
Since updating to 4.12.3 the current value (from sliders) disappears when it gets changed.
See this for example, before changing:
Before using the slider
After changing:
After sliding up
After sliding up
It reappears if you change to simple desk and then change back.
Which browser are you using?
How do you reproduce this behaviour?
thierry
Real Name: Thierry Demonty
Hello Massimo,
I'm experimenting the same problem with Chrome and Firefox browsers, when using QLC+ 4.12.4 web server on Win10 or RPi OS 10 (buster).
The (actual or percentage) value displayed on top of the slider (in Level or Submaster mode) disappears as soon as the slider is moved.
As mentioned previously, the current value reappears after switching from virtual console to simple desk and switching back to vc.
Many thanks for your massive contribution to QLC+.
Thierry.
thierry
This issue will be fixed in QLC+ 4.12.6 with the fix #1345.
