hello,
today I've tried the X-Y Pad for the first time and I like it but I've found this annoying issue, I'm on Gnome 3.36:
when entering the min and max values for the Fixture's axis, I've to write first the max value and then the min value,
otherwise the min value changes when I enter the max value.
regards
minor issue with X-Y Pad - Fixture min/max values
here a ready-made file to test it
- X-Y Pad fixture's axis.qxw
- (2.13 KiB) Downloaded 61 times
- sbenejam
I can confirm this issue. If you enter any value different from 1 in min value when change de max value min value changes to 1.
I'm on Ubuntu 20.04 with KDE Plasma.
- edogawa
- Real Name: Edgar Aichinger
By entering min and max values, you mean directly in the XY area, dragging the small square end handles of the bars at the top and left side?
If so, I cannot confirm or reproduce this under KDE5 Plasma... here i can drag any of the end points of those "sliders" and that adjusts the green rectangle just as I expect.
If not, I don't understand at all
- sbenejam
Entering the values directly in the minimum value and maximum value fields on the widget properties. I'm not tried dragging the handles.edogawa wrote: ↑Sat Aug 29, 2020 10:57 am By entering min and max values, you mean directly in the XY area, dragging the small square end handles of the bars at the top and left side?
- edogawa
Ah my bad, I was not aware of that dialog...
indeed, I can confirm the behaviour - while entering the max value by selecting the current text and typing digits, the intermediate value gets evaluated immediately, causing the min value to reset to a number lower than this current max value...
the same happens the other way around, if you enter a min value higher than what's displayed for max, max is constrained to a value higher than the current min.
I've looked at the code in ui/src/virtualconsole/vcxypadfixtureeditor.[cpp|h] briefly. The QSpinbox widget is designed to work like this, it reports value changes immediately, and the application code reacts to that signal by running a slot function, which checks for the corresponding max/min boundary.
I'm not sure what to think of this, it indeed is annoying while entering values, but OTOH it makes sense to guard against physical limits.
