Would you guys like an optimized QLC Plus on XP image?
AndrewCam100
Real Name: Andrew Modine
Because of the current situation of world health, I, as a QLC Plus user, and a fan of older Windows versions, have had a lot of free time. :)
I had the idea of making an optimized image file of Windows XP that has QLC Plus pre-installed and running on boot, just like the image for the Pi that Massimo made.
Would you guys be interested in seeing that? If so, should I use Windows XP Professional, or Windows XP Embedded?
Thanks! :D
Andrew
Do you have a license from Microsoft to distribute such an image?
Wouldn't it be a lot easier (and legal) to make an image based on Linux? Then there would be no driver hassles or any of the other problems built-in to Windows.
AndrewCam100
Linux does sound like a better idea. I will use Lubuntu. Thanks for pointing that out! I will get to work on Lubuntu.
