under windows 10 QLC 4.12.2, I launch a script "lect" which broadcasts a jpg by VLC. I then run launch a script "kill" that kills the VLC task.
The broadcasting of the VLC jpg is ok. the kill script does not stop the VLC task but in DOS command it works.
content of the kill file:
taskkill / f / im vlc.exe
I created the shortcut executed as an administrator
Thank you for your help
use command system
- Real Name: philippe thibault
- kill task.qxw
- (3.21 KiB) Downloaded 81 times
- arc en ciel.jpg (6.21 KiB) Viewed 2342 times
I am wondering why people here think VLC is the proper application to display pictures.
VLC is a VIDEO player.
In any case I think the best OS to do a picture slideshow is Linux. Not Windows. Not macOS.
Searching the forum might give results, as IIRC someone did this before...with Linux.
Otherwise, use QLC+ 5 alpha. It has native picture rendering.
The use of VLC was for the example. I want to check the system command function in a script to finally use DOS commands allowing the ON / OFF position of a video projector.
