Dear QLC+ community,
I have created a few scenes in functions and linked them to different buttons in virtual console. One of the scenes linked to one of the buttons, flashes LED par cans, and flat par cans with different colours and also moves the moving heads around again flashing with different colours. when I click the button to turn off the scene all the lights go off except the LED par cans, they continue to flash. The only way to turn them off is to either press the blackout button or exit the software and re-open it. I have noticed that the faders in simple desk are all on for the par cans. I can slide them on and off, but this is not practical during a show.
Any help will be greatly appreciated.
Thanks,
Matthew
LED Par cans won't turn off
Do they flash because you send a certain value to a specific DMX channel?
And after stopping the function - it will stay in flash mode?
Check your fixture definition if this specific channel is probably set to use LTP. In that case, you will have to hard-reset the value of this channel.
(what you try to describe using simple desk is exactly what you have to program when you want to reset the flash-mode in LTP)
(or other easy solution: change the behavior of this channel to HTP and voila...)
- Real Name: Matthew W
Thanks for this, it now works. I needed to change the program mode channel to HTP. Another thing when I have the LED par cans on program mode the Grand Master fader does not turn the par cans off. This only happens if I have the Program mode on.
Thanks,
Thanks,
Ok that makes sense, the grand master also doesn't work for the wookie laser aswell, because like the par cans it doesn't have a intensity channel.
Thanks for this.
Thanks for this.
