Hello, I will start out by saying thank you for this wonderful software. I have found QLC+ to be the solution to many projects/installs over the years. I was elated to find that there was a Raspberry version available right when I needed it for a haunted house experiment last October.
That being said, I have a few zeros running as Art-Net nodes with some custom python for theater effects. I would like to be able to walk into a venue, plug something in-line to the house dmx signal, and simply output that signal to Art-Net.
My hope is that I could use the BitWizard DMX interface with usb (FT245RL) as a DMX input to QLC+ and pass-through the data to Art-Net.
This seems like a simple question with what looks like the answer in the documentation and here on the forum, but I am on a time crunch this time and won't have the ability try more than one solution if it is not possible with this hardware. (It looks like the DMXking ethernet box will do what I need without any additional hardware, but I would rather keep the budget lower so I could have a complete backup available)
Thanks again for everything this software is capable of, as it has been the best solution for many of my projects.
Best method for DMX to Art-Net
No, you can not use it as INPUT (!)spinefan03 wrote: ↑Wed Feb 26, 2020 5:59 pm
- Real Name: Ryan Kelley
Thank you for your response, but I am still confused about something.
"use your raspberry pi as an "embedded microcontroller", that handles the DMX traffic (RX and TX) and presents an interface towards the host on the other side of the USB cable."
"There is also a version "with FT245". That version adds the option to use your raspberry pi with our board as an Enttec USB Pro compatible device from another computer (raspberry pi or PC, Windows or Linux)"
That is a quote from the bitwizard website and wiki, and from what I understand is that QLC+ can receive DMX data in from the Entec Pro USB. Do you happen to know what would be the breaking point in this process not working with QLC+? I would normally just order and test, but the time issue... My plan is to install this board onto a pi with the available software to use in "emulation mode", connect that usb to the usb on another pi or my pc running QLC+ with the "Entec Pro" selected as my input, and set that universe as a pass-through to DMX.
Sorry if I am asking the same question again but I am trying to find the actual flaw in this plan. I understand that I cannot use UART as the input method, but will the USB method not give me what I want?
Searched the forum for the proof: viewtopic.php?f=7&t=13770&p=57959&hilit ... DMX#p57973
See the screen capture from Bitwizzard's site stating that the input mode is theoretically possible but the software isn't written yet...
- floEdelmann
- Real Name: Flo Edelmann
I may link to my own Bachelor's Thesis for reference
There I documented how I implemented DMX input using OLA on a Raspberry Pi 1, but it uses some additional hardware (mostly DMX transceiver chips).
University page: http://www.mnm-team.org/pub/Fopras/edel17/
GitHub page with the sources: https://github.com/FloEdelmann/bachelor
- floEdelmann
Sorry for my late response... Thanks
Of course you may read it! It is available as a PDF linked from both the GitHub page and the university page.
- Real Name: Ralf Stresow
https://www.ulrichradig.de/home/index.php/dmx/alias-2
Hi, have a look at this module, it can be configured as DMX input via a jumper.
The module is available as a kit in the webshop of the supplier.
Best regards from Germany
