Fails to see valid OSC packets
bcrotaz
Real Name: Bryan Crotaz
MacOS QLC 4.12.2
Sending OSC packets on 127.0.0.1 to port 7700
OSC packet:
0000 02 00 00 00 45 00 00 34 9a 6e 00 00 40 11 00 00 ....E..4.n..@...
0010 0a 01 30 3c 0a 01 30 3c 1e 14 1e 14 00 20 74 ab ..0<..0<..... t.
0020 2f 66 6f 6c 6c 6f 77 2f 31 2f 70 61 6e 00 00 00 /follow/1/pan...
0030 2c 69 00 00 00 00 00 07 ,i......
Checking this against the protocol document it looks valid. Generated with Rug.OSC
In input/output manager I set up universe 1 to listen to OSC plugin on 127.0.0.1. In the plugin config I set port 7700 (default anyway)
Then created a profile, and used the wizard to detect data whilst incrementing the value in OSC every 500ms. No data detected.
No packets listed as seen:
OSC
This plugin provides input for devices supporting the OSC transmission protocol.
Input 1: 127.0.0.1
Status: Open
Packets received: 0
I've confirmed in wireshark that the packets are there and they're valid. What do I do next?
