Catalina and 4.12
- Real Name: Mark Norgren
I recently upgraded my MacBook Pro and QLC+ to 4.12. Went through and created a new show that I will be doing for Valentines. Worked on it off and on over the weekend. Last night I was using the Monitor and my laptop froze solid. I had to do a total restart. Althjough it has only happened once thus far, I'm a bit nervous about a show coming up in two weeks. Anyone in this situation or any issues with 4.12 and Calalina I should know about? Thanks in advance.
When deadlining - never change a winning team
Laptop froze solid because of?
* Qt-implementation & Catalina?
* Latest QLC+ and Catalina?
* other hardware involved which could cause troubles?
Can you revert?
Can you revert?
I've been doing a lot of programming and it seemed that when this happens, it is when I am using the Monitor. Sometimes it just closes the application, just the one time did it freeze my MacBook Pro. I have learned to save often! Never seems to happen unless the Monitor is active? My observation.
