how to set speed and fade time on chase ?
hi, I created some scenes with which I made a chase, now from the virtual console I have created a button to start and stop the chase and so far everything is ok, I would like to assign a knob or fader to change the speed of the entire chase in use, I tried with a speed dial button but I was not able can someone help me? in practice I would like to create the 2 physical sliders of the normal dmx control units (speed - fade time)
With loopback channels you can - there are quit some topic here dealing with loopback channels and bound sliders to speed dial
Give me 2$ and I'll search for you... please
search.php?keywords=loopback+channel+speed+control
I took a look at this place, I am Italian my English is limited and even if I rely on the translator I understand very little in this case
https://www.qlcplus.org/forum/viewtopic.php?f=29&t=13044&p=55411&hilit=loopback+channel+speed+control#p55411
You create a generic dimmer in a loopback universe (in & output)
now put a slider in your VC
set it to level control and choose the generic dimmer in loopback universe
now your speed dial widget - set the tempo to the channel (1) of your loopback universe.
now you can control the speed of the speed dial with the slider.
(Maybe you have to limit or change the range of the slider -> channel modifiers and or slider limits)
please make me a slider on attachment example file,i have try but don't understand good,i have udmx interface for dmx output,use version 4.12.2 qlc+
- testrosso.qxw
- (6.06 KiB) Downloaded 60 times
Here you are
1 slider controlling a channel in loopback
timer widget input control bound to channel in loopback.
- testrosso.qxw
- (7.09 KiB) Downloaded 94 times
